Yes when I turn the keyswitch to the start position I get power to both small terminals on the solenoid, should one those terminals be grounded and where it's grounded be a weak or bad ground?
Bill, nowthat you know what the problem is, check the saftey switches. 1 should be under the seat and 1 switch is to make sure your mower is off before you start the engine. Either the switches are not made or defective or the ground is off going to them.
Good luck:thumbsup:
Shouldn't you have 12volts across the 2 small terminals when the key is turned. 1 terminal should have a wire from the key switch and the other small terminal should go to ground. If I am understanding right if you are getting 12 volts on both small terminal, it sounds like there is a bad ground.
