Killed My Challnger II FM...
   / Killed My Challnger II FM... #1
PBMAX
Platinum Member
Blount County,ALABAMA
NH TC21D
Well, I don't recall the exact time a couple of weeks ago but I rember the FM drive belt poping off. So I decide to do some roto cutting rather than fight the belt back on. Leaving the finish mower set. Today I hooked up the FM and pulled around to the garage to put the belt on and check the blades.
I noticed I couldn't seem to get the belt tight so I glanced under the cover quiclky to see why.
I noticed the ACCESS hole, Funny I thought, "I don't recall an access hole there" Then it hit me what had happend and I began speaking in what the wife calls SAILOR/ NAVY.... Let just say it was a few well chosen and colorfull words....
I mananged to totally rip the right (if looking at the rear of the tractor) pully and blade assembly out completely. Guess I'll take the time next Sat to see if I can find the assembly and if I so lucky, see if it can be welded back in... If not well any one need any challenger II parts???
Will see if I can get pick of the roughly 6" hole, it was to dark by the time I finnished other chores today.....
   / Killed My Challnger II FM... #2
Hmmmm, Lil' Paul it sounds to me like you had one of those days that we all have sooner or later. I used to look back and find a wheel missing on my RFM from time to time while I was mowing until I finally locked them down using cotter pins.
I hope you get your mower back together without too much hassle.
Would you believe that with 8acres to loose something in, I actually found the whole piece laying next to the house where I first found the problem... Now I hope it welds back in with as much luck....
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
377811 (A48836)
377811 (A48836)
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
