Kimberly Ford
   / Kimberly Ford
Some alternators need to be exited to start working, there is a third terminal on them to do this. One way of doing this is to put an oil pressure idiot light switch in the circuit between the battery and the the alternator, as soon as the oil pressure up it turns off the exiciter current. The other way that I used on my 8n conversion is to open the throttle until the alternator exicited itself, somewhat easier than adding an additional circuit.
Thank you for information. I ended up replacing the one in it with a chev three also noted as a two wire alternator and it all seems to be running and charging as it should be now. It starts and runs every day so far anyway. Thanks for the information mapper.
   / Kimberly Ford #22
Glad it's working for you. Update us in regards to your projects. :)
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
UNUSED AGT SDA 140W WHEEL LOADER (A51247)
UNUSED AGT SDA...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
HURRICANE 6' X 11' CONTAINER (A51248)
HURRICANE 6' X 11'...
