I want to add this.
Ultimately, it comes down to who can provide support for you. If you've got a TSC in town and the Northern Tool is 200 miles away, well, that can make the decision for you and vice versa. I have both within 15 mintues so no big deal.
Looking at each:
Howse-
-It was better finished and more uniform. The paint job was better......seemed that more time was put into actually producing it.
-Looking underneath, the blade pan or "stump jumper" was a perfectly machined piece......round, smooth.
-The Howse is lighter, but only around 30 lbs or so. To compare the two side-by-side the KK would seem at first sight to be much heavier than that.
-The top link has a slotted area allowing some play up and down when in use. Simple.
-The Howse is lipped and ready for the all-necessary chain guard installation which is easily bought for install from the company.
-Along these lines, the lipping on the Howse provides diagonal strength. Compare a new Howse and a new KK from the front and it's likely you'll find the KK to sag somewhat. The Howse does not.
KK-
- seemed to have more steel on it and was cheaper new.
-Underneath, the stump jumper was loosely pressed looking like a Coke bottle cap but not uniform.....some edges were higher than the others and looked a little slapped-together.
-The KK is heavier, but not so much as it might look.
-The KK has a swinging top-link attachment which has more pieces and has a tendancy to bind.
-The KK is not lipped.
-This lack of lateral support allows the KK to sag along the middle. It may make no difference in operation, but it was something I noticed while looking at it and the competition.
On top of all, I've received more response from the Howse company in past communications than I have from the KK company.
Once again, all personal experience and others may have a different story to tell, but, I have had zero issue with Howse as a company or the product they offer and will buy from them in the future without any real concern. KK may be just as well, but I know what I've had and am happy with ti...
