King Kutter Carry All and I Match Compatable?
   / King Kutter Carry All and I Match Compatable? #1
Trails2004
Outside
2009 JD 3520
I have tried to search- without any luck
I recently purchased a KK carry all and when I tried to hitch to the Imatch- the top link bracket is about 3.75 to high??? The top hook of the IMatch will not connect to the top link pin- the lower pins are OK
Anyone else with this problem?? I have seen issues with HF quick hitch and the top link- however I believe this is a different issue.
Any suggestions???
Thanks
   / King Kutter Carry All and I Match Compatable? #2
Common problem...they dont follow the ASAE standard that the iMatch and other similar QH's require.
Suggestions?
-welder
-drill
   / King Kutter Carry All and I Match Compatable? #3
Is it an HF quick hitch or an iMatch?
A pic would be helpful. :)
Thanks for the response's- It is a I Match- I didnt figure that this would be an issue with King Kutter?? Live and Learn- Next time I will measure :eek:
I wasnt sure if King Kutter may have a bracket that they have produced to address the issue??
I will post a few pictures tommorrow :D
   / King Kutter Carry All and I Match Compatable? #5
Neither my KK carryall nor my KK rake were iMatch compatible, so I made an adapter. One of these days I may make some permanent changes on the carry all, but I don't see any good (easy) way to make the rake fit, so I will probably always use the adapter on it.
Finally made an adapter for the I- Match- this design is based on a "cam over" of sorts.
Materials-
2 1/2 x 3/8 strap
3/4 x 5 1/2 gr 8 bolt, washers and nut
5/8 x 5 1/2 gr 8 bolt, washer and nut
1/2 x 5 1/2 gr 8 bolt, washer and nut
A couple bushings and a short piece of 1 1/4 gas pipe.
No welding on this one :)
   / King Kutter Carry All and I Match Compatable? #7
Looks like a great fix.
I'm trying to sort out why the "cam over" but maybe it will come to me. :)
I can see there was no need for drilling or welding the KK this way. Anything else?
I guess I chose that term because the adapter pivots on the center bolt which kinda 'cams over- with the top bushing ( what I call the cam over)..:D
   / King Kutter Carry All and I Match Compatable? #9
From what I see I would call it a mechanical stop. I had to modify a tiller top mount because of incompatibility in a similar way. What is the height difference in the I-Match between the lower links and the 3rd point?
Ok mechanical stop :D This design is simalar to the adapter on my LX 5 RC.
I believe ASAE specs show 15" OC from the top hook to the lower pins on the I match. That is what I used for a starting point- this seems to work well. Both the top link and bottom pins are engaged.
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
Club Car Utility Cart (A55851)
Club Car Utility...
2022 John Deere R4023 (A60462)
2022 John Deere...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
