King of the Mountain....
   / King of the Mountain.... #11
"...I like the Kubota weight box. It looks well built...."
I would agree with that!
Junkman -- just curious -- why do you use the weight box? /forums/images/graemlins/confused.gif Seems to me that the backhoe would serve the same purpose. /forums/images/graemlins/tongue.gif
Thanx --
   / King of the Mountain.... #12
Hey that is exactly how I got my 1800 stuck yesterday for the first time!!! (well almost exactly) I even had to use the shovel to dig it out as the diff lock only made it so I had 3 tires spinning instead of 2 /forums/images/graemlins/blush.gif Guess I hadn't really thought about the fronts not locking in also until then.
Oh well live and learn!!! Actually the reason I got stuck was I lifted the bucket too soon when moving it up so I left too much to drive over so low and behold I dug her in good.
Of course I have turf tires (not loaded either) but I do have the weight box with about 300lbs. Sure was thinking I wished I had bought the rear chains at that moment, but then after I looked around and saw that nobody saw me, I decided it didn't really matter.
I agree with you Junkman that technique and knowing how not to get stuck are important. Thought I had them down too /forums/images/graemlins/smirk.gif guess I learned I still got learnin to do /forums/images/graemlins/grin.gif
Nice Piles, mine aren't quite that high yet......
   / King of the Mountain.... #13
Junkman,
You may have just caused more money to flow out of my pocket!
Have turfs on my BX...but now I think there may be a set of bar tires in my future. /forums/images/graemlins/smile.gif For winter use...
</font><font color="blue" class="small">( Junkman -- just curious -- why do you use the weight box? /forums/images/graemlins/confused.gif Seems to me that the backhoe would serve the same purpose. /forums/images/graemlins/tongue.gif
Thanx --
)</font>
I didn't like the backhoe hanging out the back because I know that at sometime I would back into something because I got careless. The box will do less damage and have less damage done to it. The box also gives a lower center of gravity for more stability in my opinion. It recommends the use of 300 pounds, but I put 600 in based on the assumption that the backhoe weighs at least that much. If 300 is good, then double is better????
...... There is no question that the bar tires are the difference in the ability to climb. I need to keep the entire front of the house clear and having used a blower in the past, I find that the loader is better for my use. I am thinking of making a snow pusher like some of the larger machines use, but don't know if it will handle the weight of the snow. This past storm put down heavy wet snow that was difficult to remove from the surface. I have noticed that I am wearing the front edge of the loader bucket by using the down pressure, however a new bucket is better than falling and getting hurt and less expensive. I have thought about a blade, but don't know if it will do a very good job from past experience with a 54" blade on my old Bolens. The Bolens was always getting stuck, and I have never been able to get the Kubota stuck, and I have tried. Some people try not to get stuck, but I believe that you have to know the limits of the machine and the only way to know them is to test them. I don't take risks, but I will push to the limit. I think that I could have climbed the pile a little higher, but didn't think that it would be of any additional value. I now know how far I can push it without damage. The filled rear tires do make a difference.
   / King of the Mountain.... #15
What is it they say... ROFL ! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / King of the Mountain.... #16
Junkman,
I've noticed you have an answer for everything must be tough to be you. Looks like your driveway is fairly level, try running that King of yours down my drive, I'll be nice and pull ya out /forums/images/graemlins/grin.gif
   / King of the Mountain.... #17
<font color="blue">Junkman,
I've noticed you have an answer for everything must be tough to be you. </font>
Might even be tougher to be his wife! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
All said in jest, naturally... /forums/images/graemlins/blush.gif
   / King of the Mountain.... #18
There are probably a lot of things that I know little or nothing about. But I do know that Junkman looks like he has the winning combination for traction with that set of tires and weight bucket. /forums/images/graemlins/grin.gif
   / King of the Mountain.... #19
I have the BX2200 with loaded turf tires and knock on wood have not got it stuck yet. The tires are loaded but I have plans on getting my tires filled by Arnco flat proofing. I also use the 2200 to pile up the snow in piles as well with no problems yet. I have my box blade on back and the Curtis cab and I have no traction problems.
   / King of the Mountain.... #20
I don't think that's a weight box, that looks more like a spreader. But I could be wrong.
Blake
WA
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
MISC WRENCHES (A53843)
2015 FORD F250 SUPER DUTY EXT. CAB (A53843)
2015 FORD F250...
1269 (A50490)
1269 (A50490)
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
