3-Point Hitch Kioti 3-pt hitch won't raise
   / Kioti 3-pt hitch won't raise #11
So is there a way to get around this? I've got a 2021 CK3510Cab and I'm wondering if you can use the "backhoe" valve as a pass-through without affecting the 3-pt? I am trying to hookup an additional summit rear remote to my already 2 existing rear remotes from the factory. I connected the summit block to the "backhoe" spool turned it on in the tractor, and lo-and-behold it worked! However I can't raise the 3pt at the same time. I'm assuming I would either have to install a t-fitting somewhere upstream and plumb that directly to the summit block, or if there is a way to run the "backhoe" and 3-pt at the same time, I'm game.
I've also got a 3rd function on the loader. Any and all help is very much appreciated, thank you!
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
25612 (A55853)
25612 (A55853)
2023 Chevrolet Tahoe SUV (A55853)
2023 Chevrolet...
2006 International 9400i (A55302)
2006 International...
2005 Ford F-350 Reading Service Truck (A55852)
2005 Ford F-350...
202476 (A54757)
202476 (A54757)
