dieselsmoke1
Platinum Member
Congratulations! Sure looks like a sweet piece! Enjoy!
pilonidal said:Congrats., looks alot like mine. Your MMM looks very different than mine, it's a MM20-60. Is that a Kioti deck? I have a rear discharge with rear support wheels also. Rear discharge is so nice with no side chute to get in the way of mowing around stuff and it evenly disperses the clippings. I want to get the new cushy seat like yours. My feel every bump/hole seat is breaking my butt. Congrats enjoy
Power in terms of torque is inverse to pedal pressure on a HST so the farther you press on the HST pedal, the less torque you have to move the tractor up a hill. If you are having trouble climbing a hill you have 2 common options. Shift to the Low Range, or let up on the HST pedal. You achieve maximum practical torque for climbing with minimal pressure on the pedal.malk315 said:- When going up a steep, long hill (on the road in my neighborhood), if I mash down the hydro in high, it bogs down. I found that gradually applying pedal until it just begins to bog and then backing off a hair yields the pedal 90% of the way down, close to full RPMs, and a nice quick forward speed (which is what I'm after when going home from Jeff's place).
You are potentially doing damage to the engine, it is called bogging down the engine and not a good thing. It happens occasionally with any engine, but you don't want to sustain it. With HST it is best to run them at PTO speed when doing any medium to heavy task. Realize diesel engines are designed to run all day at that speed without damage and you should get several thousand hours out of a diesel engine. But don't let it bog down. If your engine bogs down frequently, then you simply don't have enough horsepower for the tasks that you do on a regular basis.malk315 said:Next question: If the pedal is mashed down and engine loses bunch of RPMs since it can't do what's being thrown at it, can it be damaging to engine or hydro tranny?
No problem with that.malk315 said:One more: The mower deck height is set w/ pins on the wheels. I've found to avoid the wheels sinking into the edge of one of my landscaping beds (i.e. the caster front wheel goes of the edge and deck catches the ground) what I do is pull the hydraulic lift up until it's just about to start picking up the deck and hold it there -- that way if a wheel sinks into something, the hydraulics keep the deck up floating. Is running it like this at all bad for the hydraulics that lift 3 point and mid-mount attachments? I'm assuming not since you have a scale from 1 to 10 of infinite adjustment and the little locking screw thingy to remember an implement height -- at around #4 is where the deck and wheel contact to the ground are about equilibrium.
