Kioti ck20s tractor putting mahindra 3710 backhoe on use pto to power it??
   / Kioti ck20s tractor putting mahindra 3710 backhoe on use pto to power it??
hydraulic place told me that a 7GPM pump needs to have at least a 7gal tank and i thing i have one to put behind the seat. the pump for the pto will cost me around 400.00 and the remote lines are around 1200.00 so i gotta put the pto pump on as far as tearing up something physically, well i think as the sub frame its really strong after my welding and bracing also the tractor should be able to haul it and the weight of the tank if i cant get it behind the seat then ill weld it on the sub frame ,its small enough where it wont be in my way of ground or front loader. Might have to do a little more measuring to see if have room but i hope it does one way or another.
   / Kioti ck20s tractor putting mahindra 3710 backhoe on use pto to power it?? #12
I haven't done power beyond lines on a ck20 but I believe you should be able to do it for a couple hundred max with off the shelf parts. I doubt you have to buy the rear remotes to accomplish what you want to do.
If you can get to the power beyond line off the loader valve (goes between the loader valve and 3pt) you can make it work with a couple fittings and hoses.
   / Kioti ck20s tractor putting mahindra 3710 backhoe on use pto to power it?? #13
With the fuel tank being where it is, I'm not sure where you think you'll put the hydraulic tank? In fact because of that fuel tank the hoe sits relatively far back on a CK20. Look at the stock setup. Mine (NH hoe) has the same issue - I've got it as close to the fuel tank as I can but it still sits relatively far back.
When I modified the NH frame to connect to the tractor I went with a system very similar to how Kioti does it. Really happy with that setup. I can hook/unhook my hoe in 3-5 minutes tops.
Lastly not to beat a dead horse but where did you get the quote for $1200 for the rear remote kit? I'm positive I didn't pay anywhere close to that amount. I would expect it to be half that at the most. (Sorry I don't remember what I paid now - other than it wasn't $1200!)
E.
I went to johnsons equip. sales and they said it would be around 1200.00 for the remote kit , it did sound like a lot to me but i never questioned the man because he has worked there for 20+ years (what he said) but i did price the pto pump its gonna be 400.00. So far i haven't priced the remote lines but I don't think i can make the remote lines without a lot of work to my tractor I really dont want to mess up anything on tractor, its all stock. if i were to make the remote lines I would have to tie in to original lines of the front loader don't think i'm good enough to make it look like a factory job also for the tank it needs to be 7gal tank and i was thinking about putting it under seat where the seat bends back there is a space there that will be open may be able to mount it there and make it look pretty good (no cobble look) and should only make a 50 pound difference. I know there is gonna be a lot of weight on the sub frame and i plan on making it as close the tractor fuel tank as possible without rubbing, it might make the front a little lite but i could put some weight on the front bumper guard to compensate for the weight in back. I will check if i can find remote lines for the kioti at a resonable price but dealer said they no longer make remotes for them, but i'll see if i can price a set. thanks guys for the info keep it coming you got me thinking there are better ways to make it work.
what does the power beyond hose do on the backhoe of the mahindra do i just block it off when i put the pto pump on or does it have as much power as say what goes to the controller... as far as making remote lines for ck20s haven't had a chance to get a real good look at this option yet don't know if i can pull it off with a clean look
   / Kioti ck20s tractor putting mahindra 3710 backhoe on use pto to power it?? #16
Any chance of posting some pics of the backhoe unmounted with the tractor backed up to it about where it will be when mounted?
Also, instead of remotes, I vaguely remember a thread about a " line kit " that Kioti offered for the backhoe.
the backhoe is on a trailer right now, didn't want to set it on the ground until i get everything ready to put it together with and as far as the inline kit iv'e been looking for a ck20s kit for my kioti and haven't found anything yet can't find anything for the ck20s i guess they don't carry them anymore or something
2015 Goose Neck Cattle Trailer (A56469)
2015 Goose Neck...
UNUSED FUTURE FM57 57" HYD FLAIL MOWER (A57193)
UNUSED FUTURE FM57...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
UNUSED FUTURE XJ3T 3T HYD THUMB CLAMP (A57193)
UNUSED FUTURE XJ3T...
2017 FREIGHTLINER CACADIA DAY CAB (A57880)
2017 FREIGHTLINER...
