Kioti DK4510HS Fuel Economy
   / Kioti DK4510HS Fuel Economy #11
Agreed regarding the hp-fuel discussion. Diesel engines vary fuel:air ratio, and inherently run lean. Gasoline engines more or less maintain a constant fuel ratio.
   / Kioti DK4510HS Fuel Economy #12
Haneyrm,
You should have purchased a kubota, then you would be able to complain about fuel consumption. I like my tractor but fuel economy is not a attribute of the brand.
No argument from me here.
I bought a Kubota Grand L 6060 (53 PTO HP) about two years ago knowing full well that it was known as a guzzler.
I use it to pull a very HD 6' rotary cutter in areas that are steep, irregularly shaped and have MANY obstacles, mostly trees. A Hydrostat transmission is ideal for such work, if inefficient.
The 6060 replaced a 2007 MF 533 (2007 version of the 135), which was VERY economical. Mowing the same parcels with the same mower with the 6060 uses about three times as much fuel as did the low tech, long stroke, high torque, low RPM NA 202 CI Perkins in the 533. I expected about twice as much.
That said, the features and creature comforts of the 6060 allow me to get the mowing done in less time and with less wear and tear on me, which is why I bought it.
I might add, that the 6060 uses nearly twice as much fuel to mow other open parcels with the 6' mower as does my gear drive 90 PTO HP Kubota M9960 does with a 7' (soon to be replaced) mower.
Hydrostatic transmissions are not known for economy because considerable HP is being converted to heat. They are, however, wonderfully convenient.
SDT
   / Kioti DK4510HS Fuel Economy #13
Just back from mowing 10 acres with my new DK4510HS. Took 6.5 hours with the new tractor. Last time I mowed it, I used a New Holland Workmaster 33 and it took 8 hours.
What really surprised me was the fuel usage. With the Workmaster 33, it took 11 gallons to cut all 10 acres in 8 hours. After I finished today, I dumped a jug of fuel into the DK and it only took 5.5 gallons. I guess it's not working as hard as the Workmaster and only used half the fuel. That surprised me since the DK is much more tractor and has 40% more HP.
Definitely pleased with this machine.
Sweet!
2023 Yamaha Wave Runner Deluxe with S/A Aluminum Trailer (A51694)
2023 Yamaha Wave...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
Unused Delta Crash...
1997 Dynapac CC142 14 Series Double Drum Roller (A52384)
1997 Dynapac CC142...
2012 Freightliner M2 106 Braun Ambulance (A51692)
2012 Freightliner...
