Morgan1952
Bronze Member
Hope that someone can point me in the right direction. I have a Kioti 1914, the FEL works OK without a load on it, however with even a light load of only a few hundred pounds it won't move at all. I have noticed the 3ph running slow at times too. I have cleaned the filter, but I have not changed out the hydraulic fluid yet. I don't know if I am losing the pump or posibly a pressure relief valve is sticking. Any suggestions on where I should start? I bought the tractor used and I don't know it's history. I sure could use some help.
