Kioti LK3054 Repair Manual
   / Kioti LK3054 Repair Manual #1
crankman
Would like to know wheir I can buy a repair manual for my Kioti LK3054?? I have a oil leak that looks like it's coming from the valve cover or the top of the engine??, Where can I buy a valve cover gasket?? also the throttle control leaver does not hold the rpm's, I use a piece of wood to brace the throttle rod to keep the rpm's up while cutting grass and weed badgering. I would apreciate any help with these problems---crankman
   / Kioti LK3054 Repair Manual #2
follow the throttle level down to the pivot point. You will find an adjusting nut and a jamb nut. Loosen the jamb nut, tighten the adjusting nut to provide enough holding friction and tighten the jamb nut. It takes fairly thin wrenches and a little patience, but it works pretty well. Good luck. ps I bought manuals for my 2554 on line at a site that used to be Kioiti.com, but I think they changed it and let Kioti have the address. Maybe someone else can help with the web site name.
   / Kioti LK3054 Repair Manual #4
Bought mine from Jon Depratt at www.deprattequipment.com. Jon has been very helpful. I had to rebuild my entire engine. The parts were very inexpensive. I have all the mechanical work done. I have been so busy Jon that I have not had time to put all the electrics and body parts back on. Hope to accomplish this by grass cutting time.
   / Kioti LK3054 Repair Manual #5
One more thing crankman. Do you have a digital camera that you could take some pics of the electrical harnesses. This has been such a slow process I have kinda lost track of what went where. I will figure it out but a few close up pics from different angles sure would help. BTW mine is a 1995 model LK3054.
   / Kioti LK3054 Repair Manual #6
I was just thinking about you the other day. Was wondering if you got it all back up and going yet. Glad to hear all is well... !!
   / Kioti LK3054 Repair Manual #7
Hi Jon,
I just recieved that exhaust pipe and something else. I started in real estate in Sept. and I have been working my bunns off. If anyone is thinking of moving to middle TN drop me a line (Shameless plug /forums/images/graemlins/blush.gif) I hope the admin does not kill that. Anyways the manual is good for specs and some help but the pics are bad. Of course on the electrical they have a schematic which I am no good at. That is why it will either be trial and error (may be buying some electrical parts Jon) or find a similiar unit and get some decent pics.
Thanks to all, this is a great site. We are located in Thurman Iowa, about 35 miles south of Omaha Nebraska. We have a 6 acres of grapes and a winery. We use the Kioti 3054 for grass cutting, weed badgering, hole drilling, and post pounding,and all around dirth work. The Kioti tractor is great machine. I would if I could send digital pictures but I have Webtv and it not possible with Webtv.How big of a job to changes the valve cover gasket?? What is the price of the Kioti repair manual?? Thanks again---crankman
   / Kioti LK3054 Repair Manual #9
They now have out a new LK3054XS workshop manual which has replaced the LK3054 workshop... much better pics and more info as well...
   / Kioti LK3054 Repair Manual #10
</font><font color="blue" class="small">( How big of a job to changes the valve cover gasket?? )</font>
Easy job
</font><font color="blue" class="small">( What is the price of the Kioti repair manual?? )</font>
The service manual for my DK 35 was $65, the parts manual was $37.50. LK3054 manual prices are likely in the same area .
John Deere S780 Combine (A53342)
John Deere S780...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53472)
John Deere 5090E...
