Kioti LK3054 Repair Manual
   / Kioti LK3054 Repair Manual #12
If I could get pics of any of the wiring harnesess as they come from behind the dash and go either over , under or around the tank. It may not be possible to get any good pics without taking off a lot of body parts and I would not ask anyone to do that. But any angles you can get to would be helpful. Also the area from the starter back to the dash would be helpful. I have got to the point of re-installing the fuel tank and I am having a problem figuring out which harness goes up, through or under the tank. My direct email address is bbse@comcast.net. thanks for any pics at all. /forums/images/graemlins/tongue.gif
   / Kioti LK3054 Repair Manual #13
wiring harness should go to the left of the tank, around the side of it. Should see some wire tie spots on that side. the hole in the middle of the tank is for the tach cable and maybe one wire?? for the fuel tank sender i think.
   / Kioti LK3054 Repair Manual #14
Thanks Jon. I hope to get to work on it later this week. Most of the connectors seem to be specific. Are there any that could be crossed up that you know of and how damaging could that be? One of my great weaknesses is electrical. All the mechanical stuff was fairly simple but this has me concerned.
   / Kioti LK3054 Repair Manual #15
you shouldn't be able to switch any around.... it should be pretty straight forward when you start running the wires and making the connections... they usually just fall into place.... /forums/images/graemlins/grin.gif
   / Kioti LK3054 Repair Manual #16
For most people that would be true. For me I am not so sure. Who else could buy a tractor with 500 hrs that did not even have the paint on the bottom of the unit scratched or even have a bolt turned on the engine and then have to rebuild the entire engine? I am not taking anything for granted as I put this back together. /forums/images/graemlins/crazy.gif (Sorry for the whine)
   / Kioti LK3054 Repair Manual #17
</font><font color="blue" class="small">( Would like to know wheir I can buy a repair manual for my Kioti LK3054?? I have a oil leak that looks like it's coming from the valve cover or the top of the engine??, Where can I buy a valve cover gasket?? also the throttle control leaver does not hold the rpm's, I use a piece of wood to brace the throttle rod to keep the rpm's up while cutting grass and weed badgering. I would apreciate any help with these problems---crankman )</font> I have a parts manual that was given to me .From a dealer<It has the complete part numbers and pictures,You need the electical sch.part or the hold thing ,I will be back here the 15 around 7.00pm cen time. I can make you a copy of what you need ok.jjf10
   / Kioti LK3054 Repair Manual #18
Parts vale and wireing panei /forums/images/graemlins/smile.gif
   / Kioti LK3054 Repair Manual #19
download didnt work.Cant get it to load will try again.sorry guys /forums/images/graemlins/blush.gif
2004 Sterling Tack Truck (A52384)
2004 Sterling Tack...
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
Caterpillar Loader Quick Coupler (A53472)
Caterpillar Loader...
2020 Nifty Lift TM34TG (A51573)
2020 Nifty Lift...
(APPROX 34) 1 1/2" X 10" X 38" CHANNEL IRON (A51247)
(APPROX 34) 1 1/2"...
