Kioti Nx6010 valve issue??
   / Kioti Nx6010 valve issue?? #11
What is exactly the issue you're experiencing? Relief valves won't usually go bad.
Yes, the relief valve is adjusted by just loosening the lock nut and rotate the set screw in or out to adjust the pressure, then lock it with the lock nut. To replace only the relief valve, you would need the exact make and model of your loader valve and maybe contact them directly.
Do not mess with the pressure settings, unless you have a pressure gauge and know what the factory min and max pressure values are for that tractor.
I would think the local Parker or hydraulic jobber would have something on the shelf that would work. That said, I'm another guy who believes a quick disconnect is on the fritz.
Well the verdict is in,,,,,and y’all were right. It was a faulty quick disconnect. The same one we replaced the line on that didn’t fix it. We were close lol but I wouldn’t have guessed that. The second I told my friend what you guys thought it could be he said “that’s it, that’s it” and yep....that was it. Thanks so much fellas I’m back in action and it only cost $15. Much appreciated!!!
   / Kioti Nx6010 valve issue?? #13
great news and thank you for the update. all to often people solve their problem and never come back and update the thread
John Deere 853 20ft Corn Head (A55301)
John Deere 853...
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
JMR MINI TRAILER MOVER ATTACHMENT (A55787)
JMR MINI TRAILER...
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
