Kioti oil change type of oil, Transmission fluid
   / Kioti oil change type of oil, Transmission fluid #11
I use the Rotella 15w40. And Traveller UTF.
If you don't know the age of the Hydro Fluid I guess you should change it. Kioti says every 400 hrs.
   / Kioti oil change type of oil, Transmission fluid #12
I changed mine at 400 hrs even though the old UTF looked pristine when it came out. Better safe than sorry I guess.
   / Kioti oil change type of oil, Transmission fluid #13
I use Rotella T 15w40 year round and my tractor calls for Donax TD with has been replaced by Spirax S4 TXM which is the same as the Rotella T HD hydraulic tractor fluid sometimes sold at Walmart. Spirax/ Donax, Rotella tractor fluid is a 10w30 multigrade hydraulic oil.
   / Kioti oil change type of oil, Transmission fluid #14
Anyone using the John Deere hy guard or mystik jt5 ?
   / Kioti oil change type of oil, Transmission fluid #15
Hi,
Use factory filters and put Rotella T6 5-40 full synthetic in the engine and Kubota SUD2 synthetic trans/hyd fluid in the transmission and you will be pleased.
Brian
+ 1 Yepper!
   / Kioti oil change type of oil, Transmission fluid #16
Anyone know the API # for use in Hydraulics in a DK-40SE?
   / Kioti oil change type of oil, Transmission fluid #18
I've used the Shell Rotella 5w40. That would be a far better choice than 10w40, centainly better than that 15w40 crap they seem to be wanting to foist upon us.
A far better choice would be a good 5w30 diesel oil. That's what I use in both my tractor and Isuzu diesel generator. Would use 0w30 if I could get it in diesel (can online, but that's all, at higher cost, etc.).
Ralph
   / Kioti oil change type of oil, Transmission fluid #19
I was talking about engine oil, but if they specify 10w40 for your UTF, the same comments apply. I'd CERTAINLY want the lowest xxw__ for a UTF.
Ralph
   / Kioti oil change type of oil, Transmission fluid #20
Ralph
Mobil 1 has a 0w30. ESP formula.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
Bradley Electric Smoker and Cover (A51573)
Bradley Electric...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2239 (A51244)
2239 (A51244)
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A52472)
2019 TRITON...
STORAGE FEES (A53426)
