Kioti vs BobCat loaders ?
   / Kioti vs BobCat loaders ? #1
Slackdaddy
Land of the Free
Kioti CK20HST
Looking at the pics the bobcat CT120 has a 6TL loader and the CT230 has a 7TL loader
Rhino 6TL = 600lb lift capacity at full height
Rhino 7TL = 1035lb " " "
The kioti loaders:
KL120 (CK20) = 1074lb at max height (at pins)
KL130 (CK30) = 1155lb " " " "
A little difference on the 30HP rigs, but the 20 hp machines have a major differance.
Slack
   / Kioti vs BobCat loaders ? #4
The difference may be due to specs at pivot pin vs mid bucket so both numbers could be correct.
   / Kioti vs BobCat loaders ? #5
Ed,
Wouldn't 500mm put it about the mid bucket?
Then again.. I'm thinking 600lbs on Rhino's site might not be tractor specific.
   / Kioti vs BobCat loaders ? #6
crabjoe said:
Ed,
Yes, 500mm is essentially the same as mid bucket. I wasn't looking closely enough to see that.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
2020 Utility Trailer (A60460)
2020 Utility...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2461 (A58376)
2461 (A58376)
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
