Kitchen Flooring
/ Kitchen Flooring #1
Piperflyer
USA
Kubota3030HST
Would like to know what you recommend for a new kitchen floor and the ease of self installation. I need to decide if I want tile, laminate or real wood. Would like to see your installation if you have pictures.
/ Kitchen Flooring #2
I just helped my brother install peel and stick squares in the kitchen of his rental. I put them in a bathroom in our previous house also. Pretty easy install. Can't speak to the longevity though. Peel off the backing, stick it to your existing floor. Repeat. Trim to fit along the edges. Just make sure you get your first one in the best place as the rest will follow (make sure its square, etc).
Keith
/ Kitchen Flooring #3
We installed cork tiles in the kitchen. Very resiliant and warm on touch.
/ Kitchen Flooring #4
A lot of this is personal preference. Do you have a really good solid floor to begin with? If not, tile should be ruled out. Do you need a floor that easier on the legs? Then you should look at resilient tile, flooring or wood. I've done several floors recently. I have an engineered bamboo floating floor that was very easy to install and seems very durable. I put down a Congoleum Duraceramic that looks just like tile but installs over a plain plywood sheet. Real tile floors are still the classic, and not that expensive or hard if you don't mind spending a lot of time down on your knees.
I'm skeptical of the peel and stick stuff over the long term, but that's just my personal bias, not based on experience.
/ Kitchen Flooring #5
Well in Kanada we only put down rough chainsaw trimmed wide planking. The reason is wearing snowshoes indoors and the sled dogs at night really tear things up.
But seriously. I would go with the style of the area you live in. Different floor materials have become popular because of the climate and the local supply.
Your kitchen can have a certain look, therefore the floor should match.
If you ever need to sell your home due to a sudden illness, the new buyer has to like the place or that amount will be started to be deducted from the offer.
I need to run, the dog team is stuck cross ways coming through the front tent flap. I am hoping they will start importing doors soon.
Craig Clayton
/ Kitchen Flooring #6
We put those peel and stick things on our kitchen floor in our previous house, and for the two years they were there they were very good and didn't come away or anything.
/ Kitchen Flooring #7
I recently had dura-ceramic installed in my kitchen and dining room. Went with the grout option. It can be laid over vinyl (one layer) if floor is in good condition. Manufacture says its ok to do it. The grout is an acrylic grout and apparently has a bit for flex than standard grout to prevent cracking. The tiles are also fairly flexible to allow installation over minor imperfections in the floor. The dura ceramic is softer and warmer than ceramic tile. You won't know the difference between it and ceramic until someone bends over and touches it.
The dura ceramic is laid over a glue specifically designed for dura ceramic, then you can have the grout or no grout look. If you can lay ceramic tile, you can do dura ceramic BUT the glue is super tacky. Once you set the tile you really can't pull it up and reset it without ruining it. Based on what I saw having it professionally installed, I wouldn't do it myself unless I did floors for a living.
/ Kitchen Flooring #8
That is a wide open question. We went with a country kitchen look and I selected yellow pine flooring. We selected 6" wide T&G and the board lengths were 12 to 14 feet. The space was completely empty and we installed the floors before putting in the cabinets. Sure made the toe kick spacing a no concern. If you have base cabinets installed you have to consider removing them to put the flooring down if you go with 3/4" boards.
We like wood flooring in our kitchen, some consider it a problem with spills and such, but we have not had any major problems with that.
As for tile that was our second choice and we did put that in our summer home. It is nice, but if you drop something (dishes, glasses) go for the broom and dustpan as you will be picking it up. Tile is also pretty cold on the feet so if you live in a cold area you might consider radiant heating beneath the tiles! That's if money is not an object!
I have never looked at the stick down flooring just not our lifestyle I guess. The bottom line might be if your are doing this for a short term solution or if it is going to be long term living. I prefer wood and recommend that your go with 3/4 thickness. I would not select pre-finished flooring and do the finishing myself with a minimum of 3 coats of oil based poly. Reason for this would be to seal the spaces between the boards.
Just my thoughts...
Wayne
/ Kitchen Flooring #9
Stay away from peel and stick tiles if you live in a climate with varying moisture they don't last. We bought this house 3 years ago and the floor was just done in peel and stick and they're already coming up.
/ Kitchen Flooring #10
We went with the laminate looking tile. You have to silicone around the edge so that water doesnt get under it. We have a small/small kitchen, and we will eventually get new cabinates so I will tile then when everything is ripped out.
/ Kitchen Flooring #13
I
I'm just an ambitious amatuer and I installed the Duraceramic in a basement bathroom. I found it to be very easy to install. I used the grout (which is really a special caulk) and used the smallest tile spacers I could find. The "contact cement" nature of the adhesive kind of freaked me out, but I marked the first tile location on the floor before I put the adhesive down. It is transparent so you can see the lines after it's spread. After the first tile was down, I put down the spacers and just laid the next edge against the spacers and lowered it down. Couldn't be easier.
/ Kitchen Flooring #14
I agree, I would tackle a simple bathroom myself. The area I had done was to complicated for me. To many weird cuts, small rooms adjoining other areas, I just wasn't gonna do it. Plus I wanted it done in a timely manner and that wouldn't have happened if I did it.
/ Kitchen Flooring
I think I'm heading in the direction of the Perigo plank floor look. Looks like the installation is easy and it lasts. Any input?
/ Kitchen Flooring #16
What type of lifestyle do you have? By that I mena, do you have big dogs that are going to coming in wet and muddy? Do you take your shoes off when you come in the house? Will you sweep and clean the floor very regularly?
I am asking, because these laminate floors are great, so long as you treat them right and are protective of them. If you are likely to "ride them hard and hang them up wet", in 2 or 3 years they will look like crap (scratches, delamination, wear patterns, etc).
/ Kitchen Flooring
No animals, but the floor will get wet in the winter time from tracked boots
/ Kitchen Flooring #18
For a kitchen it doesn't get much better than--- comes in various colors and patterns to satisfy the lady of the house. She'll be changing her mind shortly anyway.
/ Kitchen Flooring
Your right about them changing their minds
/ Kitchen Flooring #20
I would use vinyl sheet flooring. The kind that has the foam backing attached.
You can cut it to rough size first then lay it out and trim the edges. You can use a little cement on the perimeter to keep it from shifting, but you don't have to glue the whole room down..
2006 Ford F-350 Pickup Truck, VIN # 1FTWX31P16EB57079 (A61165)
2006 Ford F-350...
2012 CATERPILLAR 316EL EXCAVATOR (A62129)
2012 CATERPILLAR...
2014 Freightliner 105' Bucket Truck (A63118)
2014 Freightliner...
2019 FREIGHTLINER CASCADIA 125  EVOLUTION SLEEPER TRUCK TRACTOR (A59909)
2019 FREIGHTLINER...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2020 Chevrolet Tahoe SUV (A60352)
2020 Chevrolet...
