KK blade change
   / KK blade change #1
Tanberry
N.W.Missouri
TC33DA
I've had a 5" K.K. 3pt brush cutter for about 5 years and the blades have hit alot of rocks and postes ETC and are in bad shape . I purched new blades and a socket wrench big enogh to fit over the bolds to take the blades off . They won't budge . I dont have a cutting torch , At this poit I would break them off and get new ones . Is there any tricks to getting them off ? Thanks
/forums/images/graemlins/confused.gif
   / KK blade change #2
A little heat would be the best. You could try a little propane torch. Sometimes those will heat it up enough to help break it loose.
   / KK blade change #3
A big breaker bar, preferably 3/4 inch drive, and a big hammer. Or access to a air compressor and an impact gun with some power. If doing it manually, you might have to block the blades from turning so you can get medieval on it.
   / KK blade change #4
Matt, have you checked to see if they are reverse threads? I also have a KK and if my memory is correct, they are reverse threads.
Bob
   / KK blade change
I actually got one off this evening . I had soaked them in diesel fuel last night . I put a socket on and a big breaker bar and with two guys it barly came off /forums/images/graemlins/ooo.gif I was relly just hopening it would break off until I look up the cost at 18 dollers a bolt . I think I'll try to heat the other one up tomorrow and see but it wouldn't budge . Worst case sanareo Ill load it up and take it into town . Thanks for the replys !
   / KK blade change
Oh yes they were revers thread so I had been tignting them
   / KK blade change #7
You could always take off the stump jumper at the drive spindle to make it easier to transport.
Reverse threaded? Yikes! I would have never thought.
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
20706 (A51694)
20706 (A51694)
(APPROX 34) 1 1/2" X 10" X 38" CHANNEL IRON (A51247)
(APPROX 34) 1 1/2"...
