Wayne County Hose
Veteran Member
- Joined
- Aug 24, 2007
- Messages
- 2,325
- Location
- Wayne County Pa.
- Tractor
- Massey Ferguson model 85, Allis-Chalmers WD-45
DirtHauler said:I had loader leak-down problems too. The first time was due to the factory folding the "lip" on one of the pistons when the ram was put together. The second time it did it I thought I'd blown a seal again, went down to get it fixed again under warranty but it was past a year...no go, so I bought the "packings" (sticker shock! $170.00!!!). When I pulled the rams apart there was nothing wrong with the seals BUT there was alot of "crud" in the cylinders that appeared to be pieces of hose etc. I assume from manufacturing and not being flushed prior to assembly.
$170 for a packing kit????? You could have had the cylinder rebuilt for less than that.
Your crud in the cylinders was not from the manufacturing process. It was most likely from a new hose that was not cleaned after assembly. Check out this website: Ultra Clean Technologies. If your hose shop doesn't clean and cap your hose before the sale, find another hose shop.
