knotting problems with JD 14T baler
   / knotting problems with JD 14T baler
zzvyb6 said:
and the needle lift link shear pin. If its worn or bent, the problems that result will be expensive.
My lift link is welded, so i guess that would be a bad thing...
Also noticed that someone put in a large bolt in place of the auger shear pin, probably also not good :(
Methinks a parts baler is in order! was the 14T a popular machine back in the day? Wondering how hard it will be to source one in the area.
   / knotting problems with JD 14T baler #22
As a matter of fact, I have a bolt in the auger drive of mine. No big deal, just don't run a fully completed bale thru the machine, or a log or a deer carcass, or a fence post. The twine problems may be eliminated if you use square bale twine. Sounds like you picked up some round bale twine...
...or a fence post.
Been there, done that... with the mower anyways :p
Wasn't even done my second pass and a temporary post i had been using to mark some stuff in the winter time had fallen over, and thinking I had already removed them all ran right over it. Luckily no serious damage, just a broken tooth and a popped off ball-socket joint :)
I'll double-check to make sure it's square bale twine, but I think it is... its thicker than the other stuff i was using (both sisal) but this newer one doesn't seem any stronger, just not wound as tightly. Thanks for the tip tho, I didn't know there was a difference, just figured small bales used sisal and big bales used nylon stuff!
Dan
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2012 VOLVO A30F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A30F...
UNUSED IRANCH MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED IRANCH MINI...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
