Kohler Command CH25S rocker installation
   / Kohler Command CH25S rocker installation #1
macindude
Hubertus, WI
Simplicity Legacy
Hi all,
I was watching a YouTube video about this engine and they talked about how there's a little depression in the cylinder head where the bumps on the rocker pivots go, and showed using a wrench to twist the pivot while torquing the bolt so that it sits correctly in the head and stays aligned.
I am just building up a new cylinder head, and my pivots have the bumps (either side of the bolt):
However, the head is perfectly smooth, with nowhere for those bumps to sit:
How should the rocker arm pivots be installed so that they don't twist around? What is the method used to correctly align the rockers?
FWIW, I grabbed the old cylinder head and it didn't have the depressions in the head either. Given how it practically fell apart as soon as I took the head off, I'm wondering if a twisted rocker pivot is part of the reason my push rod bent.
Thanks!
Kent
   / Kohler Command CH25S rocker installation #2
I have always just eyeballed the alignment and torqued the rocker bolt to spec. the older Commands had a trough that the rocker sat in to keep it straight.
   / Kohler Command CH25S rocker installation #3
So, you never found the reason why your pushrod bent? If that is the case, a set of lifters would be in order I'd think.
Yep, totally new head, valves, lifters, etc.
FWIW, here is what I'm talking about:
I don't have the slot, so looking for what I should be doing instead.
   / Kohler Command CH25S rocker installation #6
I saw what he did there in regards to locating the rocker and securing it. That looks fine to me. There's give there but I suppose one could get a thin straight edge across the square base of the pivots and they should be aligned. I looked down for a bit and then noticed he was using RTV, kinda lost me there. So I didn't really watch more. Bleeding the lifters I hope?
Ah, that's a good idea. So the two rocker pivots should be parallel? Or is there a slight V to them? Looked like the latter to me, but I'd also prefer something more precise than "well, that seems about right".
As far as the lifters, I got new ones. Nothing to bleed. Local dealer's head mechanic said *not* to soak and bleed, but just to install them dry.
Just popped the other valve cover off again for a look and the rocker pivots on that side are circular. There’s also a slight V between the rocker arms.
   / Kohler Command CH25S rocker installation #9
Right, but I’m not reinstalling any lifters. I installed two new ones on the side I opened up. They’re dry, so there’s nothing in them to bleed. Right?
1996 Moxy MT30S Haul Truck (A55272)
1996 Moxy MT30S...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
Mini Excavator Tracks (A56857)
Mini Excavator...
2019 PJ TRAILER 32FT GOOSENECK (A58216)
2019 PJ TRAILER...
9ft Reading Service Bed (A57453)
9ft Reading...
NEW FRONTIER 4N1 BUCKET (A52708)
NEW FRONTIER 4N1...
