Kohler Courage puffs smoke
   / Kohler Courage puffs smoke #21
Kohler Engines has a Service Bulletin/Kit that addresses smoking during operation at an angle on the Courage Twin engine. The engine was found to be oversensitive near the full oil level. The problem is most prevalent on applications where the engine rests with the dipstick in an even slightly up/raised position. The kit includes a gasket to better seal the breather system and a modified dipstick that lowers the oil level just slightly. You may find leveling the engine/unit on a slight incline on your yard or driveway, and then adjusting your oil accordingly may solve your problem without the update. Kohler Dealers can work with their sources of supply/technical support to assure your satisfaction. You can use 800-544-2444 to locate your local dealer if needed.
   / Kohler Courage puffs smoke #22
Sort of like a mosquito fogger......:laughing:
The Kawasaki on my 60" tank exhibits the same scenario. I just run it halfway down the dipstick.
2012 Nissan Maxima Sedan (A51694)
2012 Nissan Maxima...
2014 Vermeer SC802 Towable Stump Cutter (A51691)
2014 Vermeer SC802...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
ITEM LOCATION (A53084)
UNUSED WOLVERINE PT-16-01C UNIVERSAL ADAPTER (A51248)
UNUSED WOLVERINE...
