lobsta1
- Joined
- Oct 12, 2009
- Messages
- 6
I have a CC 1315 with the Kohler 12.5 spec 1211. For the last year I have been fighting an intermittent starting problem. Headlights not turning on all the time led me to a flakey ignition switch. No cranking at times & stomping down on clutch/brake pedal led to replacing the deck switch. Still having problems starting at times had me bypassing reverse switch. Still starting problems that I finally realized usually only happened when warm. Cranks fine, but no spark at a grounded spark plug. There is no separate coil on this model. This leads me to think that the ignition module/magneto is failing when warm. Before I spend $50 on a new module, does this sound like I am on the right track.
Al
Al
