kohler engine acts like its starving for gas intermittantly
   / kohler engine acts like its starving for gas intermittantly #21
Good to know I'm not alone, apparently this is a common symptom with Kohlers.. aside from those caused by bad fuel & filters. I have a 6 month old Kohler Pro CV492S 18hp and it starts and runs fine for 30-45 minutes then begins to stall like it's has fuel starvation or out of gas. Wait a while and it will run again which makes it sound like a temperature related electrical problem. The carb fuel bowl solenoid shuts off fuel flow to the carb when the key is off and prevents dieseling too.. might also be tripped by a safety tip over sensor to kill the engine. I read on other forums that the solenoid can become corroded by water in the bowl and cause trouble but I found a repair tech had already disabled the solenoid by cutting off center pin on mine.. For another shot to find a cure I used a can of dust off to chill the ignition module on the chance it was hot (even though it was cool to touch, apparently some designs get warm enough to require a heatsink). One forum suggested the fuel line was getting hot and causing the fuel to vaporize but I don't think it's the problem here. I have good fuel flow from the tank to the bowl with a new 60 micron filter & new gas. Guess I'll keep reading.. the thing farts when I shut it off too.
Sounds like at this point you don't know whether the problem is fuel or ignition. Run the engine until it stalls, then pour a teaspoon of gas down the carb. If it starts and runs the problem is fuel, if it won't start you have no spark. It doesn't help to overthink these problems; most of the time it is pretty simple.
One question I would ask is why the tech disconnected the solenoid on a 6 month old engine. Maybe done as a troubleshooting aid to fix a fuel delivery problem?
   / kohler engine acts like its starving for gas intermittantly #22
The solenoid is an electromechanical device and could stick in either the off or on position. When you turned the ignition on did you hear a click from the solenoid?
John Deere 612C Corn Head (A59814)
John Deere 612C...
10 ft Wrought Iron Fence (A56859)
10 ft Wrought Iron...
Copper Horse Weathervane (A57454)
Copper Horse...
2014 Yamaha YRDEX4 Electric Cart (A56859)
2014 Yamaha YRDEX4...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
24220 (A56859)
24220 (A56859)
