Kohler K181t 30768d ignition questions
   / Kohler K181t 30768d ignition questions #1
khavekost
I have an Ariens rototiller with a motor from Kohler. It has a magneto ignition, and I can get no spark from it. I've taken the flywheel off and cleaned things up as much as I can, but I'm still getting no spark. I am also not finding any sites that carry the magneto, so I'm at a loss.
Any suggestions? Hints?
Thanks in advance.
Ken
   / Kohler K181t 30768d ignition questions #2
Google the model number of your Kohler motor and you should find many places with parts.
If you go to the Kohler web site and put in your model number, select workshop manual and read the manual for how to test your ign system.
   / Kohler K181t 30768d ignition questions #3
The "T" stands for "Pull start,magneto ignition"
Look on Ebay,under K181 (forget about the T)
I saw at least 6 coils for sale,for magneto ignition.
The points are the same on all the K series,but the condensor is different on magneto ones.
Those are on Ebay too-#47 147 01-s
   / Kohler K181t 30768d ignition questions #4
I have the same problem with a Troy-built horse tiller. Put 3 mags on it, no good. Magnet in the flywheel is weak. I put a battery, coil and condenser. Wired it with a kill switch, works like a charm. I do have to charge the battery at night tho. Still looking for a good flywheel, don't have 500 bucks for a new one, can't find anyplace to recharge the magnet.
2016 Chevrolet Tahoe 4x4 SUV (A46684)
2016 Chevrolet...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
Calumet Pit Pump (A49251)
Calumet Pit Pump...
Gehl 135 Mixer (A49251)
Gehl 135 Mixer...
2001 Chevrolet C6500 Wrecker Tow Truck (A48081)
2001 Chevrolet...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A46683)
2017 Mack GU713...
