Koyker 160 joystick boot replacement
   / Koyker 160 joystick boot replacement #1
GRUMPA
Concho, AZ
KAMA/TS354C 35HP 4 cyl 4 wheel drive
After almost 3yrs I finally got back in the drivers seat to do some much needed work. The first thing I did was raise the FEL and the boot split right at 1 of the creases and it needs to be replaced. I've looked on the net and I found 1place so far but there $35+shipping is a bit out reach for a boot. Has anyone found a cheaper replacement? If someone has can you share where you got it?
   / Koyker 160 joystick boot replacement #3
Mine split too, sounds like it's not an uncommon problem. What I did however, was to rotate it around - so that the split was at the bottom. Then I used a 12" cable tie down at the rectangular end that (a) held the split closed and (b) held the boot in place over the hardware underneath.
//greg//
   / Koyker 160 joystick boot replacement #4
Mine split too. I made one with some tanned moose hide I had laying around. Cheap and works great!
Harvey
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
Quick Coupler (A53316)
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2019 Chevrolet Suburban SUV (A55758)
2019 Chevrolet...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
40' CONTAINER (A51244)
