Koyker FEL Help!
   / Koyker FEL Help! #11
Some valves have PB to pass the fluid downstream for other valves.
The PB port is rated for full pressure.
If your tractor FEL was designed for the psi, and GPM's required, downstream valves should work off the tank port, although there is the potential to damage the FEL tank port, as most of them are rated for only about 500 psi.
Most literature says that all tank ports should go to tank.
If you want to run log splitter, BH, remote valves, etc, the PB would be necessary.
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
