KUBOTA 2410 and 2710
   / KUBOTA 2410 and 2710 #11
<font color=blue>a 5ft unit is to much wght for the size of the 2410</font color=blue>
Don't think this is a fair statement at all. There are many different weights for rotary cutters, and almost all of the ones I saw are well within the weight limits of the 2410. If you get a light/mid weight 5' cutter (mine is about 520 lbs) you are fine. The 2410 is rated to lift 1300 lbs 24" behind the lift point. The FEL (LA352) for the 2410 acts as an excellent counter weight. The other point is that a heavy duty 4' cutter can weigh more than a light weight 5' cutter.
Obviously one should not use a heavy duty 5' rotary cutter without anything on the front end. Use caution and be safe.
Kevin
   / KUBOTA 2410 and 2710 #12
After a 110 hrs on my 2410 and some of those hrs using my 5' rotary cutter, I would totally agree with Knight9. Weight is not an issue as long as the loader is on. I have also cut grass over 3' tall, but at a fairly slow ground speed.
   / KUBOTA 2410 and 2710 #13
Ditto!! Just bought a used 1995 B2400 with just over a thousand hours and its life has been spent doing mostly bush hogging contracting by its previous owner. It handles a 5' light duty Landpride brush hog with no problem (351 FEL attached). I put it through its paces for about 5 hrs in all sorts of conditions : flat pasture 8-12" tall grass in H range,
3-4' brush, weeds, and small saplings(less than 1" thick) in L range with great success. It speaks well for Kubotas! It starts and runs just like the new ones. It may be too big for this little tractor, but it doesn't seem to realize it yet. Rob
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
2007 JLG 600S TELESCOPIC MANLIFT (A52705)
2007 JLG 600S...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
