Backhoe Kubota 4690a BH
   / Kubota 4690a BH #1
moralem
I have a 2006 L2800 and am looking for a backhoe attachment and have come across a model 4690 for about 2800 dollars. Will this backhoe fit my L2800 and what else should I know about this backhoe. Thanks.
   / Kubota 4690a BH #2
The good news: Yes, it should fit your tractor.
The not entirely good news: The reason it should fit is it's a 3 point mount backhoe, not a subframe type. The 3 point setups have limitations in strength and ease of mounting compared to the more costly subframe type backhoes. They're intended for light-moderate use, not the really hard stuff. If your need is for an occasional, mostly light-duty tool, the 4690 is a good one and you've got a good price. As long as you're not planning to use it for deepening the Panama Canal or something similar, it's a good choice.
   / Kubota 4690a BH
I don't plan on any major work. Mostly around my 5 acres to plant trees and to dig up waterlines for repair and for laying irrigation lines. What would be considered heavy work. I don't want to damage my tractor.....
   / Kubota 4690a BH #4
Removing boulders and large tree stumps is heavy work. Also, if your soil conditions involve rocks, shale and ledge, you need something that will stand up to it.
Otherwise, for landscaping work or laying a water or power line, I would think you should be OK, as long as you are careful.
Two things to be aware of:
a) Can't speak from personal experience, but I've been told that 3 point backhoes can be a bear to get mounted.
b) You'll need a reinforcing kit from Kubota for the toplink mounts on the tractor. The 3 point backhoe hookup puts a lot of stress on the tractor rear end and it's highly recommended that an additional strengthening bracket be added. There are many discussions in the Kubota Owning and Operating forum about this. Search using the keyword "4690". Here's one thread that has some images of what the reinforcing brackets look like.
http://www.tractorbynet.com/forums/...74-3-point-backhoe-4690-l.html?highlight=4690
Maybe if you're lucky, the seller has the correct reinforcing kit and will make it part of the sale. Otherwise, you'll be doing some business with a dealer, I suppose.
JLG 1255 Telehandler (A52748)
JLG 1255...
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
2005 Cat DP40KL Forklift (RUNS) (A50774)
2005 Cat DP40KL...
Vermeer 840 Discbine (A50774)
Vermeer 840...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
