Kubota 7030 vs M9000
   / Kubota 7030 vs M9000 #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
Other than 20hp what are the major differences? They seem to be about the same size and the tires could be the same size too.
thanks,
Bill
   / Kubota 7030 vs M9000 #3
If the M9000 has a hydraulic shuttle, it’s a much better transmission than the 7030 dry clutch.
M9000 2-3 mph faster in top gear, so it runs down the road faster, too.
I would prefer the M9000
   / Kubota 7030 vs M9000 #4
HST is fine for “back and forth” such as FEL-work… but I mostly use my tractor for mowing and maintaining roads. The geared tranny and dry clutch is much more durable with regard to overheating, maintenance and durability for that.
   / Kubota 7030 vs M9000 #5
It’s not an HST (hydrostatic), it’s a hydraulic shuttle (reverser).
Its more durable and lasts longer than a dry clutch. It’s what is found in larger farm tractors, like mine.
   / Kubota 7030 vs M9000 #6
yes to this. go hyd shuttle if the M9000 has it. superior to conventional dry clutch in longevity & repeat performance
also keep in mind, hyd shuttle and shuttle shift are 2 different systems. hyd is wet pack clutch, shuttle shift is dry clutch. hyd requires no clutch depress in F/R, while the shuttle shift does...the hyd shuttle is a superior system in terms of use & longevity
   / Kubota 7030 vs M9000 #7
Price and condition? Hyd shuttle (if equipped) and a newer model +more power in the M9000 would be more appealing.
   / Kubota 7030 vs M9000 #8
I was looking at a M6950 (approx. same age) and contacted Messicks to see about parts availability. I was told maintenance parts available, but replacement parts could be "iffy". I passed on it, consider parts availability.
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
HYUNDAI 740-9 (A52472)
