Kubota 7100 loader leaky cylinder
   / Kubota 7100 loader leaky cylinder #1
vaxman
Ontario, Canada
Kubota B7100
I am unable to identify the cylinder manufacturer and wonder how I can so I can get seals. Where is the best place for seals? Also, the barrel is scored and is there any fix?
Thank you in advance------Jim
   / Kubota 7100 loader leaky cylinder #2
Did you mean the piston was scored?
A couple options. if you have a mom-n-pop hyd shp take it to them.. they can re-piston and reseal the ram. Alternately, if the piston wasn't bad.. all you would need would be the od of the piston and the id of the seat for the seal, and the depth the seal sets in for a bearing/seal shop to match it up.
In desperate situations I have seen a large expensive piston brazed and honed/polished smooth as a quick fix to prevent a very costly repair. I consider that a last ditch idea.
Soundguy
Piston is fine------its the barrel
Jim
   / Kubota 7100 loader leaky cylinder #4
Any shop should have the capability to fix you up. If it's Kubota the dealer will have parts.
Egon
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2014 LAMAR TRAILER (A53843)
2014 LAMAR TRAILER...
SDLANCH TRACKED MINI LOADER (A53843)
SDLANCH TRACKED...
GENERATOR (A53843)
GENERATOR (A53843)
1999 CASE 721C WHEEL LOADER (A53843)
1999 CASE 721C...
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
