Kubota 7100 loader leaky cylinder
   / Kubota 7100 loader leaky cylinder #1
vaxman
Ontario, Canada
Kubota B7100
I am unable to identify the cylinder manufacturer and wonder how I can so I can get seals. Where is the best place for seals? Also, the barrel is scored and is there any fix?
Thank you in advance------Jim
   / Kubota 7100 loader leaky cylinder #2
Did you mean the piston was scored?
A couple options. if you have a mom-n-pop hyd shp take it to them.. they can re-piston and reseal the ram. Alternately, if the piston wasn't bad.. all you would need would be the od of the piston and the id of the seat for the seal, and the depth the seal sets in for a bearing/seal shop to match it up.
In desperate situations I have seen a large expensive piston brazed and honed/polished smooth as a quick fix to prevent a very costly repair. I consider that a last ditch idea.
Soundguy
Piston is fine------its the barrel
Jim
   / Kubota 7100 loader leaky cylinder #4
Any shop should have the capability to fix you up. If it's Kubota the dealer will have parts.
Egon
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2025 International TMA Attenuator Truck (A52377)
2025 International...
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2020 Chevrolet Tahoe SUV (A52377)
2020 Chevrolet...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
