Grease the fitting under the tractor for the pedal, as said before. Next check the damper shock, it could be bad. Then the neutral spring, it's ajustable. More then likely you well have to pull some sheet metal off to get to the adjuster for the spring. It looks like it might be hard to get to, I don't think you can do it under the tractor but you can see it.
