Kubota B series HSD pedal
   / Kubota B series HSD pedal #1
Chicojohn
KUBOTA b7610HSD
Kubota B7610HSD pedal does not return to neutral. A sure cure would be greatly appreciated.
Thanks - John
   / Kubota B series HSD pedal #2
Not being familiar with that set up at all. Is the pedal linkage gummed up with debris? Is the pedal moving the tractor at all? Are the fluid levels correct for the transmission. Any springs on it that are broken?
Let one of the other guys that know about those chime in and give you some better answers.
   / Kubota B series HSD pedal #3
Is the pedal linkage clean and working smoothly?
My old Kubota "B" had a zerk on the HST pedal pivot point. Keeping it clean and properly lubed really helped. I would start there.
I hit all the zerks every 10 hours. Kinda a pain, on my current tractor, the book lists like 40 zerks!
   / Kubota B series HSD pedal #4
Check that all the linkage parts move freely. if yours has a V notched plate with roller that centers in the notch ensure nothing is bent and the roller is running in the proper place.:D
   / Kubota B series HSD pedal #5
Grease the fitting under the tractor for the pedal, as said before. Next check the damper shock, it could be bad. Then the neutral spring, it's ajustable. More then likely you well have to pull some sheet metal off to get to the adjuster for the spring. It looks like it might be hard to get to, I don't think you can do it under the tractor but you can see it.
Thanks for all the reply(s). Your help is fantastic. I have cleaned and lubed all the moving parts on the pedal linkage with little change. Not sure how to make adjustments to the damper shock or neutral spring. I will try to find a parts diagram on the web.
______________
John in Chico, CA
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
2017 Freightliner M2 106 Medium Duty Truck, VIN # 3ALHCYCY5HDJD6749 (A55788)
2017 Freightliner...
2006 GMC W5500 Truck, VIN # J8DE5J16367903094 (A55788)
2006 GMC W5500...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2020 Ford F-150 Crew Cab Pickup Truck (A55788)
2020 Ford F-150...
