Kubota B2100 HSD techie question
   / Kubota B2100 HSD techie question #1
rocky2
Pittsburgh, Pennsylvania
B2910
ok, so I went brain dead for a few minutes changing the hydro oil on my B2100 HSD.
The question is, there's a 17mm capscrew smack dap in the lower middle on the front of the rear transmission case, right where a steel hydro line comes from the filter. Hmmm, same size as the drain plugs, hence the brain dead comes into play.
Inside there is (was) a spring and a cone shaped piece, I'm assuming a pressure relief. Anyway, it came out and I'm wondering and checking with the gurus if I put it back in the correct way.
I put it in cone first, taper inwards to the case, then the spring into the recess on the capscrew.
Won't even use the excuse that I was scampering from under the 'bota and changing the oil on the jeep, and having to chase the puppy thru the woods. Sometimes multiprocessing doesn't work right. And yes, the shop manual was ordered last weekend.
Thanks
   / Kubota B2100 HSD techie question #2
I think you got it right. I did the same thing the first time I changed the oil on mt B2400.
   / Kubota B2100 HSD techie question #3
Thanks Hayden. I appreciate the second opinion for some peace of mind. I didn't do the dumb on the first change, but I've been running the lil thing pretty hard this past summer on my new property. Even though I have only 130 total hours, it's cheaper in the long run to do filters and fluids. Besides, the Kubota may grow up to be like my other toys, the Harley and the Vette...when those two are neglected...it's worse than the ex and her attorney.
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
(INOP) MASSEY FERGUSON 1552 TRACTOR (A59823)
(INOP) MASSEY...
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A56438)
2017 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
