Kubota B2320 shutting off while mowing
   / Kubota B2320 shutting off while mowing #1
M Allen
Berea, KY
Kubota B2320
My Kubota B2320 tractor has been shutting off while mowing. It will shut off and then start right back up. Will do this several times during a 2 hour mowing. Then I can use it to mow for 2 or 3 hours a few days later and it will run fine. Anyone have any idea what might be wrong?
   / Kubota B2320 shutting off while mowing #2
If it's only doing this while mowing I would suspect a short in the seat safety switch.
Actually tractor does it when in use, not just when mowing. Doesn't happen every time I use it, will run just fine for a few weeks and then it will shut off 3-4 times while using.
   / Kubota B2320 shutting off while mowing #4
Although others may disagree Kubota's are pretty rock solid and basic. That's why I will always have one. If mine acts up it's usually a stupid safety switch somewhere. To name some:
Seat safety switch.
Hydro pedal switch.
PTO safety switch.
It depends how it is shutting down. If it's an instant kill like turning off the ignition switch most likely it is a safety switch. If it's sputtering, engine missing, or losing power before shutting down that would suggest more a fuel or air delivery problem.
   / Kubota B2320 shutting off while mowing #5
I second or maybe its third by now ~seat switch~
   / Kubota B2320 shutting off while mowing #6
feather weight problem aka tractor seat switch?
2016 John Deere 6110M Utility Tractor (A50657)
2016 John Deere...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2000 KOMATSU VALMET 860.4 FORWARDER (A51222)
2000 KOMATSU...
