Kubota B3350 12 V inside power connector??
   / Kubota B3350 12 V inside power connector?? #1
speedyvelo
Black Hawk, CO
Kubota L6060
Q: what power plug fits the connector inside the cub under the coffee cup holder
and where can I get it.
I want to install a back up camera and I have read the great thread started by 94builitt in this forum. I would like to use the internal power plug in my tractor and would be great to find the male of the adapter that comes with the tractor. Yes I could use separate cables but having the same type of adapter is my preference.
Thanks
-=terry=-
   / Kubota B3350 12 V inside power connector?? #2
Varmint,
Thxs for your reply, unfortunately the accessory connector behind the seat in this Kubota B3350 is not a cigarette lighter type but is like a plastic casing that has two quick disconnects type of terminals that are arranged in T, so one is vertical the other is horizontal. I have never seen one of those connector but I am not an expert either.
-=terry=-
   / Kubota B3350 12 V inside power connector?? #4
Varmint,
-=terry=-
Often those type of T connectors can be bought online -- check DigiKey or Mouser and plan to spend a lot of time sorting the search results.
Many of them on Kubotas use standard 1/4" blade connectors for terminals inside the connector, so you have a couple options -- either make up your harness with 1/4" connectors and individually push them into the existing connector's terminals, or slide the individual terminal contacts out of the connector and hook up mating 1/4" connectors that way. That's what I did when wiring up custom rear work lights on my L3200 -- it's a permanent install and I didn't see the need to have the connector there anymore (it's really only for convenience when connecting the factory work light kit with the mating plug).
A small flat screwdriver is usually all that's needed to release the holding tabs to get terminals out of a connector. Once out you'll see they are standard 1/4" blade type, assuming what you described matches what I have seen on other Kubotas.
   / Kubota B3350 12 V inside power connector?? #5
Ah- my L3400 has those, as well. I also used the 1/4" blade connectors, like s219, with tape around the whole thing to keep it clean and dry. No problems.
Guys,
Thank you.
I will use the 1/4 quick disconnects as you are doing it. Interesting Aaron message shows that seems to be a proprietary connector use by Kubota.
Well I will work on it as soon as weather improves.
The storm we are having now will be the first big test with the tractor.
-=terry
   / Kubota B3350 12 V inside power connector?? #8
Guys,
Thank you.
-=terry
Its not proprietary, just uncommon around here. They are called a "2 Way T Shape Spade" connector.
Aaron Z
   / Kubota B3350 12 V inside power connector?? #9
Yeah, I don't think it's proprietary either -- seen those used a lot. You should be able to find a generic version for a lot less money than Kubota wants, though shipping may kill you -- seems like you can't buy anything online without spending at least $6-7 for shipping these days.
Thanks again.
I wonder why Kubota went with this weird connector. I did a little search and it seems the few places they offer them are in the UK.
Well it not a big deal
-=terry=-
20'x12' Livestock Metal Shed (A53316)
20'x12' Livestock...
2014 CATERPILLAR 289D SKID STEER (A52706)
2014 CATERPILLAR...
New/Unused CFG Industrial QK18R Mini Excavator (A54865)
New/Unused CFG...
2019 John Deere 5045E (A53314)
2019 John Deere...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
2018 Ram 1500 Pick Up (A47477)
2018 Ram 1500 Pick...
