Price Check Kubota B7500
   / Kubota B7500
I sure want to thank EVERYONE who has responded to my post. TBN is a super site. Everyone has spoken very positively about the Kubota B7500. I think I'm going to pull the trigger this Saturday on the one I have been considering. I'm anxious to get it, and I'll try to post some photos when I get it. I'm really looking forward to being more active on TBN like many of you have been. Thanks again all of you. One last thing. Even though this tractor has very low hours, 138, is there anything I should look at carefully, mechanically, before I take delivery?
   / Kubota B7500 #12
I would just check out everything, and see that it works,, look for leaks, check the hydraulic and hydro filters, and see they are not gray, (original eqpt is gray) any other color is ok, and will have writing on it. If they are the same color as the chassis (kubota gray) then they have never been changed, Not the end of the world, as it only has 138 hrs, but should have been done at 50. Put the blade on the 3pt and see it goes up smoothly, it should. It is and inching valve, and if you move it slowly it will jump up in little 1/4 inch jumps (or appproximately) It does not have position control, but thats not a real big deal. check the loader for all functions. Check the hydro is smooth forward and back.. That's about all I can think of. Good luck, We all think you are getting a pretty good deal, and if you noticed, almost a dozen guys think the B7500 is a good little tractor. I would rather have it than a BX as it has higher ground clearance, which can be very important at times. In 8 years I rode mine pretty hard, and put it away wet, but it never faltered, or complained or ever let me down.
James K0UA
   / Kubota B7500 #13
DEK,
I own a 2003 B7500 with 500hrs. Never a problem. It has done everything I have asked of it. Maintanince as per the owners manual. Great machine.
Ray
   / Kubota B7500 #14
I think I'm going to pull the trigger this Saturday on the one I have been considering....
If everyone else thinks its a good deal too then there's a good chance it won't be there by Saturday. Not sure if you found it on Craigslist or what, but anything that is a 'deal' doesn't stick around. I''d suggest being there tomorrow if you really want it.
   / Kubota B7500 #15
Hi guys....just joined TBN. I am looking for a good, reliable 4x4 tractor that has a loader and backhoe on it (homeowner in rural town with 2 acres). I am trying to keep the price below 10K if possible. Here's a local Craig's List ad I found on the Kubota B7500:
For sale is a 2000 Kubota B7500 with LA 272 Front End Loader. Tractor is in great shape, 680 hours, 3 forward gears with reverse; high and low speed transfer case; tractor has 4 wheel drive and locking rear diff. Mid and Rear PTO, hydro lines all good, tractor starts right up and runs as if brand new. Tires are R4 Industrial tires and are not worn, tires are also loaded, giving more stability when using FEL and when on a hill sideways. Light weight and plenty power, can drive over septic w/o problems, good size for homowner or landscaper. Needs nothing, bring it home and put it to work right away. Looking for $9000 or best reasonible offer. Any questions e-mail or call 203-843-2691; delivery can be negotiated.
I see that the other tractor had more options and lower hours for 10K.
Any suggestions?
Eric
Bethany, CT
   / Kubota B7500
Eric,
Welcome to TBN.
I think $9K is high. If it had the hydrostatic transmission, the larger loader L302, and less hours, it might be a price worth considering. According to the ad, the seller is open to offers. If you can check the tractor out, you might have a better feel for what you're going to offer. I would think $8-8.5K would be reasonable. The B7500 is a tough little partner. If it has been well maintained and not abused, it'll go a long time. Make sure you try everything mechanical to make sure there are no surprises. (Transmission-shifts in all gears, all gears and ranges functional, no noises; hydraulics work; motor starts easily, doesn't smoke, no blow-by; no leaks; cosmetics; tires; service history; . . .
Only you can decide what you are willing to pay. Do your homework and you will feel fine with your decision. Good luck.
   / Kubota B7500 #17
2019 John Deere HPX 815E (A50121)
2019 John Deere...
2017 Kubota U55-4 (A50120)
2017 Kubota U55-4...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
2018 Kubota SVL95-2s (A50120)
2018 Kubota...
2012 Cat 272C Skidloader (RIDE AND DRIVE) (A50774)
2012 Cat 272C...
