kubota b7510 or JD 4115 ?
   / kubota b7510 or JD 4115 ? #1
tractor1971
Alberta, Canada
Yanmar 240
Please help me with my choice between these two tractors? The JD has 2 horsepower more, but cost C$4000 more with the same size tiller,mmm and FEL. Will be used for mowing, some ground work. The size of land will vary in future, likely bigger, therefor the bigger tractor. It's for a lifetime.... Help me out with some comments?
   / kubota b7510 or JD 4115 ? #2
When I go to the Kubota comparison page, Kubota compares the 4115 with the 7610. That is why you are seeing some of the price difference. Your not apples to apples there. So you are paying for the higher horsepower in the John Deere. I would go back and compare the 7610 with your pricing or the John Deere 4110 to your pricing. I don't think you will see a 4k difference anymore. Also make sure the options are equivalent also. Once you get your new pricing then I would look at the price and then look at each dealer. Even if you spend a bit more money in the long run it may pay off. No tractor is good without a good dealer to back it up. As far as the two brands, one is not any better than the other. Which one do you like, and which one do you want to run over the next twenty years and again make sure your dealer is good.
Also if you got time go back in and fill out your profile as to the whereabouts you live. This way people in your area can help you better with pricing as pricing varies from area to area.
And welcome to TBN. You can get a lot of information here.
murph
2020 Chevrolet Silverado 3500 HD 4X4 Service Truck (A52377)
2020 Chevrolet...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53472)
Michelin CARGOXBIB...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
