kubota b8200 rear axle seal replace ment
   / kubota b8200 rear axle seal replace ment #1
james b
kubota b8200
hi have a b8200 kubota and need to replace the left rear axle seal that is leaking and my question is does any one know if the bearing and seal is pressed on or if it is held on by a snap ring any help/ pics. would be great !!thanks james
   / kubota b8200 rear axle seal replace ment #2
The inner bearing is either a slight press fit with a snap-ring, or just a slight press fit. Meaning you shouldn't need to take it to a machine shop to have removed. Two pry bars usually does the trick. And for the outer bearing I usually just drive it out with a plastic dead blow hammer. It is really a pretty easy job.
Brian
thanks for the info i will let you know how it goes
thanks for the info ! had to use a 3 jaw puller though would not move with pry bars but i got it done thanks again .:thumbsup::drink:
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2015 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52705)
2015 CATERPILLAR...
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2009 GMC C5500 Landscape Dump Truck (A55788)
2009 GMC C5500...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
