kubota back hoe issues
   / kubota back hoe issues
Update on my kobota back hoe. I ordered the pump you suggested JJ, and mounted it to my 13 hp engine, then removed the busted section of hydraulic valve and made 1 1/2 spacers out of steel tubing from tractor supply, put the valve back together, drilled two new holes for the mount of the valve where it was shorter and it worked great. Bought two 12" casters I am going to mount to the front of the hoe so the gravely does'nt have to lift it up, all it will have to do is tow it and it should articulate well. Now just need to get a single spool valve with pb and hose it in for the swing cylinders.
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A56435)
2025 Wacker Neuson...
2022 Ford F-450 Super Duty STX Pickup Truck, VIN: 1FT8W4DT2NEC20764, Crew Cab, 4x4, Fx4 Off Road, (A59076)
2022 Ford F-450...
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
2017 DODGE RAM 2500 (A58214)
2017 DODGE RAM...
Honda ES 6500 Generator (A55973)
Honda ES 6500...
