Backhoe Kubota backhoe is 3pt mount ok ????
   / Kubota backhoe is 3pt mount ok ????
Thanks, Thats ed zachery what Im a gonna dooo /forums/images/graemlins/confused.gif
   / Kubota backhoe is 3pt mount ok ???? #12
i recently aquired a compact 4WD tractor along with a 3pt mount BH. Since then, I have designed and built a subframe so as not to over stress the lift arm and top link anchor points. chances are the tractor specs require a subframe.
if you use the unit for occasional light use, a 3pt mount might be okay. for commerial and/or heavy duty use, seriously consider a subframe.
best regards,
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55314)
PENDING SELLER...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
