Backhoe Kubota backhoe is 3pt mount ok ????
   / Kubota backhoe is 3pt mount ok ????
Thanks, Thats ed zachery what Im a gonna dooo /forums/images/graemlins/confused.gif
   / Kubota backhoe is 3pt mount ok ???? #12
i recently aquired a compact 4WD tractor along with a 3pt mount BH. Since then, I have designed and built a subframe so as not to over stress the lift arm and top link anchor points. chances are the tractor specs require a subframe.
if you use the unit for occasional light use, a 3pt mount might be okay. for commerial and/or heavy duty use, seriously consider a subframe.
best regards,
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
Truck Absorptions Attenuator (A54865)
Truck Absorptions...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2025 MAMMOTH SB-2 2025 SAND BOX TRAILER (A56129)
2025 MAMMOTH SB-2...
