Kubota block heater help
   / Kubota block heater help #1
camco
EHC, NJ
b2350
I want to do the install on my tractor.
I have a L355SS ( shuttle shift ) and the shuttle shift oil pump is in front of the freeze plug that is used to install the normal threaded block heater.
Can anyone tell me if there is another location that I am able to install the block heater into.
   / Kubota block heater help #2
Went to Messicks site and looked at the parts diagrams and they do not list one.
Kubota has many block heaters available, usually your dealer has a little cheat sheet listing the part number recommended for what tractor and application and which freeze plug to use. For example on a BX with a 902 engine, they use a side freeze plug but an RTV with a 902 will sometimes use the freeze plug in the head. The side threaded plug is sometimes used as an alternate location for a radiator hose and is an easy one unless their is an appliance hanging in the way. You may have to just get a good caliper and measure the size, usually in mm and find one at the dealer with the pound in sleave, and find one by size.
If that does not work there is always a hose type if room allows.
David Kb7uns
Block heater for the L355SS is discontinued.
That is right from the Kubota dealers mouth.
They don't even list a part number for what heater was used.
   / Kubota block heater help #4
Considering that tractor hasn't been in production for nearly 25 years it really isn't a surprise.
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52128)
2019 New Holland...
2019 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
