Kubota Brake Adjustment: FAIL
   / Kubota Brake Adjustment: FAIL #21
You'll still have to put a ton of force on that little turnbuckle even with the heat. I thought something was going to break. I used a 12"pipe wrench and crescent wrench to get it to budge. After it moved a 1/16 inch one way I kept moving it back and forth and kept appyling Kroil. Let me know how you make out...Good Luck.
Same exact experience except I did my first adjust at 1700 hours.
I had to heat the SNOTS out of the turn buckle with a MAP gas torch and I was neither happy nor impressed with the design.
BTW, only one end of the turn buckle has a lock nut. the other end has what looks like one, but it is not. I destroyed one end and had to drill and tap it to re thread the rod.
These tractors are bullet proof, but they are a pain in the tail to work on.
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2005 Peterbilt 387 with Wet Kit (A55314)
2005 Peterbilt 387...
More info coming soon! (A55787)
More info coming...
