skyhook
Veteran Member
- Joined
- Mar 12, 2013
- Messages
- 1,906
- Location
- Canada Ontario
- Tractor
- 1996 Kubota L4200 GSTC,(sold) 1994 JCB 210S 4x4x4
OK,
I should have mentioned that the reason I need Vbar is because I have a slope that has a 20-25 grade and it will ice over.
Anyways, so far I learned that Vbar is Vbar and along with having the tires loaded + ballast box it will grip.
Braking:
If I have the diff locked and in 4 wheel then I am technically stopping the wheels in the front via the tranny.
Thanks for the advice, 20 grand is not chump change for me.
I did pick that up in your first sentence of your first post.
again, in "your" circumstances, I would consider a larger machine,
if not new, then a good second hand one.
A ballast box on a smaller tractor "may" help, but in the conditions you described, I doubt it,
you need a good "stance" of a machine, the wider and further apart the tires are,
and the heavier the machine, the better off you'll be, in your situation. IMO
