Kubota BX 2200 Power Steering
   / Kubota BX 2200 Power Steering #1
Anonymous Poster
Epic Contributor
I have 145 hrs on the BX. I have just developed a problem with the power steering. I can slowly rotate the streering wheel to the left and the front wheels don't turn. If I turn it quik they will turn. When I mow I am constantly turning the steering wheel to the left. Turning right seams to work fine. I feel that it may be weak bypass spring in the steering valve, if there is one. I don't think the steering cylinder would be leaking past the piston but that may be happening. Any thoughts out there? HAs anyone had the same problem?
Sounds like your assumptions may be right. I'd suspect a bad seal in the steering cylinder /forums/images/graemlins/confused.gif.
DaveL
Just had the same type problem on a knife gate. When I would regulate the flow down it wouldn't move but at high flow it would work ok. When I disassembled the cylinder the piston seals were shot. There was no noticable wear to the liner so I just replaced the seals and it works fine. I would definitely check any bypass valves if they exist before I tore down a cylinder.
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2019 ExMark Lazer Z S-Series 72in Zero Turn Mower (A51691)
2019 ExMark Lazer...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
80in HD Tooth Bucket with Side Cutters (A53472)
80in HD Tooth...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2002 Fleetwood Expedition 36ft Class A Motorhome (A51694)
2002 Fleetwood...
