Kubota BX2200 HST Shudder - Barely Moves
   / Kubota BX2200 HST Shudder - Barely Moves
Aaron,
Thanks for the suggestion. I have not done that - I don’t see any frothing or anything, but that sounds like something worth I try before I tear into it.
Thanks!
Tom
Hello All,
Thank you for your responses. I thought I would provide an update to hopefully help people in the future.
After I determined my charge pressure was low, and tried all the quick fixes (new filters, cleaned strainer, bleed air, etc), I still had no luck. I ended up picking up a lightly used HST online. I installed it (took about 4 hours to get everything apart and 6 hours to get everything back together). Also cleaned and put new boots on the propeller shaft joints and replaced the fan. I would recommend doing these things as they are cheap and easy while you have everything apart.
Once I got everything reassembled, I checked the charge pressure and it was back within spec.
Long story short, it looks like the problem was internal to the HST. I am going to tear down the old one to see the exact failure mode when I get a chance. My suspicion is that the unit got too hot; the fan was intact but there was a ton of mud and dirt caked on the HST, so I知 sure the heat transfer was not very good.
Overall wasn稚 a bad job...much easier than it looked. The hardest parts were a few spring pins that were corroded in place. Other than that very manageable DIY project.
Thanks,
Tom
   / Kubota BX2200 HST Shudder - Barely Moves #13
I was wondering where you found your used transmission? I have a bx2200 with very similar issues.
NISSAN 60 MAST FORKLIFT (A55745)
NISSAN 60 MAST...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2016 Chevrolet Malibu Sedan (A55853)
2016 Chevrolet...
2005 Ford Explorer 4X4 SUV (A55758)
2005 Ford Explorer...
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
