I used super UDT fluid as required by Kubota. I jacked up the back of the tractor and it didn't seem to make noise like it does under when driving the tractor. It seems to have enogh pressure because I can lift the tractor off the ground using the fel and backhoe. I did notice that when driving the tractor up a 30 degree slope it makes more noise when extra power is needed, especially when in high . I also notice the rear tires seem to viberate, almost feels like air got into the hydraulic system. I always checked the HST fluid level and never had to add any fluid. Also worth mentioning is the noise subsides when i get to top speed in both high and low range on flat ground. If I am in high range at half throttle and slowly push on the trendle to go forward the viberation makes the whole tractor viberate.
