Kubota dragon soft underbelly
   / Kubota dragon soft underbelly #1
RickOliver
My new BX2230 had all of 6 hours on it when the fuel line was severed by...a stick. That's right a stick, and not a very big one. Luckily the rip was near a connection point and there was enough slack for me to just cut off the bad part and reconnect, but a lot of diesel fuel got dumped on me and the ground in the process.
While I was under there poking around I noticed that there seemed to be a lot of very exposed lines. I guess they wouldn't be so exposed if I had a mid-mount mower, but I didn't buy a tractor to mow the lawn. In fact, I don't have a lawn. Any thoughts on attaching a metal plate -- or even a piece of wood -- to the mid-mount brackets to protect this creature's inordinately soft underbelly?
   / Kubota dragon soft underbelly #2
Do a search on "skidplate" and/or "skid plate" and you will find several threads including some pictures of skidplates folks have built.
Ground clearance was my primary reason for buying a B7510 rather than a BX2230.
Bill Tolle
   / Kubota dragon soft underbelly #3
We had a dozer that was put out of commision by a very small twig of a tree. The dozer had skidplates, a protected operator's station, and lots and lots of shielding. However, there was a very small hole near the underside of the operator's station where a fuel line fitting went. The part was about 69 cents, but the labor to take everything apart to reach where the stick had gone... $400! Sometimes its the small stuff that gets you, not the big ones.
   / Kubota dragon soft underbelly #5
Here's my take on the BX2200. It was designed for a primary task of cutting grass very well and secondly to do other tasks adequately. It's low ground clearance and "tender underbelly" is a hinderance to "off roading".
As opposed to the B7500, that is designed to do other tasks very well and secondly cut grass adequately.
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
UNUSED JMR 40" HYD ROCK GRAPPLE (A54757)
UNUSED JMR 40" HYD...
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A55787)
2018 Caterpillar...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
